Schleuniger Provides Automation and Quality for Dräxlmaier Group
Apr 29, 2014
CrimpCenter 67 HD16
CrimpCenter 67 HD16
The Dräxlmaier Group, founded in 1958 and headquartered in Germany, supplies renowned vehicle manufacturers with modern automotive electrical systems as well as exclusive interiors integrated with electrical and electronic components. Prior to working with Schleuniger, Dräxlmaier’s method for processing battery wire consisted of two stages: automatic cable cutting and stripping and manual crimping. To increase productivity, the company needed a solution that would allow them to perform both processes in one automated step. But, being a supplier to some of the most well-known and high-end brands in the automotive industry, Dräxlmaier knew they could not sacrifice quality for productivity. To improve the production process according to Dräxlmaier standards, they took advantage of Schleuniger’s extensive experience in wire processing and worked with them to create a customized solution.
After extensive research and testing, Dräxlmaier chose the Schleuniger CrimpCenter 67 HD16. With processing stations for automatic cutting, stripping and crimping combined with Schleuniger’s ACO 05 crimp force monitor, which electronically monitors each crimp and compares the measured value to a known good reference crimp, Dräxlmaier automated their entire process while guaranteeing quality. Furthermore, Schleuniger customized the machine to specifically fit Dräxlmaier’s need to process wires up to 25 mm2.
Ulises Benítez, Equipment Planning Manager, Dräxlmaier Components Automotive De México, says since they have implemented Schleuniger equipment, they have seen “significantly reduced process time, material handling and investments for semi-automatic crimping as well as increased valuable space on the production floor.”
The CrimpCenter 67 HD16 is now a standard equipment for any of Dräxlmaier’s over 50 facilities world-wide that need to process this application.
Apr 03, 2020 -
CrimpCenter 64 SP - Produce Faster, More Precisely, More Cost Effectively
Feb 14, 2020 -
Schleuniger, Inc. to Exhibit Wire Processing Equipment at the 2020 Del Mar Electronics and Manufacturing Show
Nov 12, 2019 -
Schleuniger Press Release - BHC Cable Assemblies Relies on Schleuniger Precision and Durability
Sep 12, 2019 -
Schleuniger, Inc. to Exhibit Latest Wire Processing Innovations at M-Expo
Sep 12, 2019 -
Schleuniger, Inc. to Exhibit Latest Wire Processing Advances at ATX Minneapolis
Sep 12, 2019 -
Schleuniger, Inc. to Exhibit Latest Wire Processing Advances at The ASSEMBLY Show
Apr 03, 2018 -
Schleuniger, Inc. to Debut New Wire Processing Equipment at Electrical Wire Processing Technology Expo
Jan 17, 2018 -
Schleuniger Introduces CableCoiler 1450 Single Pan Coiling System
Nov 27, 2017 -
Acquisition of majority stake in adaptronic Prüftechnik GmbH
Jun 22, 2017 -
Schleuniger, Inc. Receives 2017 Best of Manchester Award
14 more news from Schleuniger, Inc. »
Schleuniger Provides Automation and Quality for Dräxlmaier Group news release has been viewed 1779 times
Facility Closure
Dual Lane Reflow Oven
