High-Precision, High-Mix, Print-Place-Reflow Package Under $47K
Jan 30, 2014
SMT turnkey assembly systems, reconfigured and expanded to accommodate a wider range of production levels and budgets.
Manncorp has recently reconfigured and expanded its exclusive selection of SMT turnkey packages, including stencil printers, pick and place machines, and reflow ovens, to accommodate a wider range of production levels and budgets. Among the ten different turnkeys presented on their website at www.manncorp.com/turnkeys is the new 2500-MV package. Priced at only $46,995, the 2500-MV is designed for companies with a limited budget and minimal floor space who need short-run, in-house production capability for ultra-precise, high component-mix SMT assembly.
The cornerstone of the 2500-MV is the MC-400 pick and place system, featuring Cognex® on-the-fly and bottom vision alignment, for high-accuracy, 2500 CPH placement of a wide range of advanced SMDs—from 0201 chip components to BGAs and 15 mil ultra-fine-pitch devices. The MC-400 has the capacity for up to 64 automatic “smart” tape feeders and can also accept a wide variety of stick, cut-strip, and IC tray holders. Built upon the same architecture as Manncorp’s popular MC Series of SMT pick and place machines, MC-400 feeders and software are compatible with all other MC series equipment.
The 2500-MV includes the heavy-duty MC-110 stencil printer —the industry’s most robust, highest-precision, manual printer with a repeatability of ±0.02 mm (less than 1 mil). Its universal mounting bracket allows clamping or screw mounting of frames up to 740 mm x 740 mm (29” x 29”) and tool-free, self-locking, X-Y-Z and theta axis adjustments provide quick and easy stencil to pad alignment.
The profilable MC-301 batch reflow oven rounds out the 2500-MV and simulates the performance of an inline system in a compact benchtop design. Through its innovative user interface and Android operating system, preheat, soak, reflow, and cooling stages are easily programmed to conform to component and paste manufacturer’s precise specifications. For process control and traceability, solder profiles are easily saved and distributed via built-in WiFi.
To learn more about the 2500-MV or other SMT turnkey systems available from Manncorp, please go to www.manncorp.com/turnkeys.
May 16, 2014 -
Improved Dip Soldering Systems Have Wider Range of Capability
Mar 25, 2014 -
Android(TM) Operating System Controls New Benchtop Reflow Oven
Sep 28, 2013 -
Closed-Loop, Zero-Discharge PCB Cleaning System in Operation at Manncorp DEMO Center
Jul 27, 2013 -
Manncorp Installs Selective Soldering and Fluxing Systems at Calsonic Kansei Mexicana
Jun 20, 2013 -
Manncorp Opens New Corporate & SMT DEMO Center
Jun 20, 2013 -
Dross Separator Recovers Solder and Saves Money Fast
Feb 08, 2013 -
New High-speed Pick & Place Machine for Nonstop Production of LED Boards
Oct 09, 2012 -
Manncorp Brings High-Precision, Selective Soldering and Fluxing to the Bench-Top with the New ULTIMA Series
Sep 20, 2012 -
Computer-Controlled Batch Reflow With Real-Time Profiling Mimcs Inline Reflow
Jul 31, 2012 -
Batch SMT Assembly & Prototyping Made Efficient, Reliable and Affordable
39 more news from Manncorp »
High-Precision, High-Mix, Print-Place-Reflow Package Under $47K news release has been viewed 901 times
