LED PCB
Mar 05, 2009
Thermal Management Applications for LED Solutions
Browning White Soldermask
White soldermask is commonly used in LED PCB board applications with metal core. A common failure mode for the end OEM is a browning of the soldermask. This browning occurs as a result of the cumulative heat cycles the board is exposed to during the soldermask baking and HASL processes at the PCB fabricator as well as reflow and wave solder at the PCB assembly operation.
SuperWhite Soldermask
We are working with our soldermask suppliers as well as suppliers not traditionally associated with the PCB industry to develop a SuperWhite soldermask that can withstand not only multiple heat cycles during the PCB Fabrication and Assembly Manufacturing processes, but also while in the field. We expect completion of this program during Q2 2009.
Light-Emitting Diode Solutions for PCBs
The need for thermal management seems to have started in military applications, but it's use is becoming widespread in power and light emitting diode (LED) PCB applications.
Our customers span a wide range of industries, including: Military; Telecommunications; LED; and Automotive.
For more information Thermal Management PCB Boards and their application to Light-Emitting Diodes (LEDs) follow this link:
http://saturnelectronics.com/thermalmanagement.htm
Mar 30, 2016 -
Saturn Electronics Corporation Supporting U of M Autonomy project
Oct 21, 2014 -
The University of Michigan Solar Car Team To Represent the Saturn Electronics at the 2014 SAE Convergence
Mar 18, 2013 -
Domestic PCB Fabricator Certifies Nine Employees as IPC Application Specialists Per IPC-A-600
Mar 16, 2011 -
Consult LED Thermal Management Expert
Nov 09, 2010 -
Via Plugging Guidelines
Sep 30, 2010 -
Yash Sutariya to Present at IPC Technology Interchange on Thermal Management: Getting the Heat Out
Sep 08, 2010 -
Via Hole Filling
Mar 05, 2010 -
New Material & Fabrication Process Improves LED PCB Thermal Conductivity
Dec 01, 2009 -
Thermal Management for LED Applications
Oct 27, 2009 -
LED MCPCBs
31 more news from Saturn Electronics Corporation »
LED PCB news release has been viewed 348 times
Fluid Dispensers
