LED PWB Design
In LED PWB design, assembly and fabrication, the PCB designer is always conscious of price, production capability and manufacturability.
DFM Engineers and PCB Designers
Saturn's DFM Engineers are always ready to assist PCB Design Engineers in all aspects of the design for manufacturability. A major trend they've noticed is the thermal material choice for applications in LED board fabrication .
Define Your Needs Before Choosing PCB Thermal Materials
When specifying materials, do you specify your thermal pcb needs or do you select your materials by brand name? Are you specifying by brand name or by temperature?
PCB Specifications for Thermal Management of LED PCBs
Instead of calling out materials by brand name, Saturn's DFM Engineers recommend choosing the PCB specifications that best suit your purpose and meet your needs.
LED PCB Fabrication Applications Webinar
In addition, the thermal management LED PCB fabrication applications webinar promises to address the applications of thermal management; why thermal management is needed for LED board fabrication; surveys pertaining to heat management characteristics, heat dissipation, and applicable PCB heatsinks .
Why spec in material when you should be spec'ing in your needs.
