The new expanded series of Panasonic replacement nozzles for high-speed (eight and 12-nozzle, Type A-0 and A-2) and multi-functional (Type B) placement heads offers a high productivity, low-cost alternative to OEM nozzles.
Most standard nozzles are available in a variety of materials, such as high strength plastic, tool steel, ceramic and diamond (PCD). All Panasonic CM nozzles from Count On Tools use the same reflectors as the OEM with a special hard coating to provide waterproofing, prevent scratches, and increase tool life and overall durability. COT CM nozzles also are compatible with the equipments’ chip thickness measuring sensor, if equipped.
Count On Tools provides custom engineered nozzle designs from the OEM as well as special nozzle designs for odd-form components (LED, connector, grippers, etc.). The company specializes in nozzle rework as an alternative to purchasing new nozzles. Count On Tools also offers cone-shaped XS filters for the Panasonic CM Series.
The CM Nozzle range is guaranteed to function properly with the following Panasonic/KME pick-and-place equipment: CM20F, CM301-D, CM301-DU, CM301-DS, DT401, DT401-M, DT401-F, DT400-M, CM401-M, CM401-L, CM402-M, CM402-L, CM400-M, CM212-M, CM232, CM201-D, CM202-D, CM201-DU, CM202-DU, CM201-DH, CM202-DH, CM202-DHU, CM201-DS, CM202-DS, CM202-DK, and CM602-L.
Every nozzle manufactured by Count On Tools comes standard with a 100 percent satisfaction guarantee. If any customer is not 100 percent satisfied with the performance or quality of a product, Count On Tools will replace it or offer a full refund.
