UVLED curing machine is generally used for UV glue, UV ink and other UV coating curing, can achieve the purpose of rapid deep curing, the principle is UV irradiation special glue causes glue to produce polymerization reaction to cure.
UVLED light curing machine output single band is not visible, focus on a particular wavelength of plus or minus 5.0 nm.
The LEDs are a kind of solid state device;
They can be composed of light-emitting diodes of various wavelengths, including but not limited to 365, 385, 395, 405, and 410nm.
This is different from the wide spectrum emitted by traditional UV lamps.
This monochromatic distribution requires new chemical formulations to ensure proper curing of uv-curable materials.
Main application points
UVLED light curing machine is suitable for the mini speaker, electronic industry, speakers, speaker, receiver, headphones, ear plugs, photovoltaic, optical fiber, microelectronic assembly glue, IC protection seal, integrated circuit chips, glass chip, wire bonding, bare chip seal assembly, electronic materials, UV curing adhesive, surface coating, and coating materials, optical adhesive, receive, reinforcing with adhesive and so on.
TORCH is specialized in r&d and production of high-power UVLED vacuum welding oven, which has been successfully used in many high-power UVLED vacuum welding ovens at home and abroad, and can replace imported UVLED vacuum furnace seamlessly.
If you are interested in our products, please visit our website(www.torch.cc) or search UVLED vacuum oven on baidu to learn about our products.
