Gen3 Systems Limited, a specialist British manufacturer and distributor, is pleased to announce that it will exhibit at the S.E.E. show in Stockholm, scheduled to take place April 19-21 at the Kista Expo Center. Gen3 will showcase its solderability and contamination testers with its Swedish distributor, ESD Centre, in Booth CO2:30.
Gen3 will display the new, award-winning contaminometerTM, in particular the CM22+ will be displayed. The CM+ features:
Complete testing within only 3 minutes
The entire tank volume is re-circulated 6 times every minute (CM33L up to 240 litres per minute)
Unique solid gold measuring cell, ballistic amplifier providing a test accuracy of <0.005mS/cm
Unique CURVE-FITTING Analysis algorithm (Merit of Fit)
Full regeneration in typically < 6 minutes
Smooth bubble-free circulation at all times
Accurate measurement even when the proportion of test solution to surface area under test are huge
Automatic temperature compensation
Measures in accordance with all international and MIL specifications old and new
New range of PCB/Component handling frames, with integrated draining system.
The CM Series comprises: CM11+, CM22+, CM33+, CM33L+, CM60 and CMBBT.
Also on display, the MUST System 3 is the latest technological evolution of the original Multicore Universal Solderability Tester (MUST) that grandfathered all modern solderability test standards. It remains the unquestioned industry benchmark for solderability testing. Capable of measuring down to 0.001mN the MUST is the most accurate and comprehensively equipped test system of its type in the world.
In addition to the above, Gen3 also manufactures conformal coating process equipment – bench-top and in-line systems, and SIR, CAF and solderability testing systems. The company also offers a range of test services. Gen3 distributes products for ACE, Finetech, Optilia, Vacunest, Stoelting, Hirox and MBTech.
Additionally, the MUST 3 will be part of Bob Willis’ special production area, booth C01:39, with two surface mount production lines – one high-volume and one for New Product Introduction (NPI). Here you will find a Live Production Feature showcasing all production processes. All results of the testing carried out will be presented at the conference on the Sept. 8, 2016, details to be announced at the show.
For more information about Gen3 Systems, visit www.gen3systems.com.
Gen3 Systems is a specialist manufacturer of test and measurement equipment used to help predict reliability of electronic circuits and systems in the field. In addition, the company designs and manufactures dip and spray coating process equipment in both in-line and bench-top formats. Gen3 is a specialist distributor for several leading equipment manufacturers including, ACE, FineTech, MBTech, MEK, Hirox, Optilia and, Aprotec Instrumentation, Solder Paste Inspection (SPI) systems.
Gen3 Systems also provides training, equipment and expertise for manufacturers requiring assessment of their electronic products’ reliability. The company also operates a test service and assists with standards development via both the IPC and IEC. Gen3 Systems operates from premises near Farnborough Business Park, on the M3 corridor and just 30 minutes from London’s Heathrow Airport.
