Gen3 Systems Limited, a specialist British manufacturer and distributor, will exhibit in Booth #219 with Ascentech, LLC at SMTA International, scheduled to take place Sept. 27-28, 2016 at the Donald Stephens Convention Center in Rosemont, IL.
The global award-winning Gensonic Stencil Cleaning, system will be displayed with a 24" stencil frame. The system uses a 40kHz on-contact ultrasonic transducer for high efficiency cleaning of stencil apertures. The Gensonic can be used either in conjunction with Gen3 stencil cleaning centres or is portable enough to be taken directly to the printer.
Gen3 also will display the award-winning contaminometerTM , in particular the CM22+ will be displayed. The CM+ features:
Complete testing within only 3 minutes
The entire tank volume is re-circulated 6 times every minute (CM33L up to 240 litres per minute)
Unique solid gold measuring cell, ballistic amplifier providing a test accuracy of <0.005mS/cm
Unique CURVE-FITTING Analysis algorithm (Merit of Fit)
Full regeneration in typically < 6 minutes
Smooth bubble-free circulation at all times
Accurate measurement even when the proportion of test solution to surface area under test are huge
Automatic temperature compensation
Measures in accordance with all international and MIL specifications old and new
New range of PCB/Component handling frames, with integrated draining system.
The CM Series comprises: CM11+, CM22+, CM33+, CM33L+, CM60 and CMBBT.
In addition to the above, Gen3 also manufactures conformal coating process equipment – bench-top and in-line systems, and SIR, CAF and solderability testing systems. The company also offers a range of test services. Gen3 distributes products for ACE, Finetech, Optilia, Vacunest, Stoelting, Hirox and MBTech..
Gen3 Systems is a specialist manufacturer of test and measurement equipment used to help predict reliability of electronic circuits and systems in the field. In addition, the company designs and manufactures dip and spray coating process equipment in both in-line and bench-top formats. Gen3 is a specialist distributor for several leading equipment manufacturers including, ACE, Hirox, FineTech, MBTech, MEK, Optilia and, most recently, Global Distributor for Aprotec Instrumentation, Solder Paste Inspection (SPI) systems.
Gen3 Systems also provides training, equipment and expertise for manufacturers requiring assessment of their electronic products’ reliability. The company also operates a test service and assists with standards development via both the IPC and IEC. Gen3 Systems operates from premises near Farnborough Business Park, on the M3 corridor and just 30 minutes from London’s Heathrow Airport. For more information about Gen3 Systems, visit www.gen3systems.com.
