Gen3 Systems Limited, a specialist British manufacturer and distributor, will exhibit in Booth #3136 with Ascentech, LLC at the 2017 IPC APEX EXPO, scheduled to take place Feb. 14-16, 2017 at the San Diego Convention Center in California. Gen3 and Ascentech will demonstrate the new CM+ Series and AutoSIR 2/AutoCAF 2.
The 6-Sigma, award-winning ionic contamination test systems CM+ Series will be on display.
The CM+ Series are the world’s only combined ROSE and PICT Ionic Contamination Test System.
The CM+ Series features include:
Complete testing within only 3 minutes
The entire tank volume is re-circulated 6 times every minute (CM33L up to 240 litres per minute)
Unique solid gold measuring cell, ballistic amplifier providing a test accuracy of <0.005mS/cm
Unique CURVE-FITTING Analysis algorithm (Merit of Fit)
Full regeneration in typically < 6 minutes
Smooth bubble-free circulation at all times
Accurate measurement even when the proportion of test solution to surface area under test are huge
Automatic temperature compensation
Measures in accordance with all international and MIL specifications old and new
New range of PCB/Component handling frames, with integrated draining system.
The Contaminometer series from Gen3 Systems come in 6 different models and 6 different tank sizes - when selecting a Test System, for optimum results, it is important to use the smallest possible tank size for the circuit under test. The CM+ Series comprise: CM11+, CM22+, CM33+, CM33L+, CM60 and CMBBT.
Also on the booth will be the Award Winning AutoSIR 2 / AutoCAF 2 Insulation Resistance Testers.
The key features of both the NEW AutoSIR2 and AutoCAF2 Measurement systems provide the following product enhancements:
Measurement Time: 256 Channels <8 seconds
Applied Voltage: +1V to +500V
CLR1000 extends the test voltage to 1000V
Measurement Range: 106 ω to 1014 ω
Measurement Method: Continuous on all selected tests
Measurement Test Intervals: Fully selectable from minimum of one minute
Capable of testing to all existing test specifications IPC - IEC - JNC and other user specifications
Both the AutoSIR2 and AutoCAF2 Systems are available with 64, 128 or 256 channel configurations.
Gen3 Systems also will give a joint presentation with Robert Bosch on the subject of Process Ionic Contamination Testing achieving 6-Sigma verification.
Gen3 Systems’ new Chief Technology Officer, Dr Chris Hunt will present as all, and will discuss verification testing for the new IPC-B-53 Test Coupon for the next revision of the SIR Test Method.
Gen3 Systems Limited is a specialist British manufacturer and distributor of test and measurement equipment used to predict reliability and maintain quality in the production of electronic circuits. We are a small team of experts offering not only equipment and test services but also full customer training and consultancy services in specialist areas.
Gen3 Systems works closely with the world-renowned UK National Physical Laboratory (NPL) that helps with the development of new measurement techniques and equipment. We are engaged in international standards development through the BSi, IEC and IPC. Our combined knowledge and experience is also employed to provide training and advice to customers, along with a range of comprehensive in-house services for solderability, SIR and cleanliness testing. For more information about Gen3 Systems, visit www.gen3systems.com.
