Gen3 a British manufacturer of testing and measuring the electronics industry announced that Dr Chris Hunt, CTO, will present during the SMTA Electronics in Harsh Environments Conference. The presentation, “Objective Evidence and How to Convince the Auditors,” will take place on Wednesday, May 18, 2022, from 16:30 – 17:00 pm at the Park Plaza Victoria Amsterdam.
Gen3’s Dr Chris Hunt will be addressing the question that everyone is facing in the industry globally, what does ”Objective Evidence “ mean / require?
- This will be a measurement system that will be repeatable and reproducible, and that can have a metric that directly relates to performance.
- For ECM a suitable metric is resistance.
- ECM produces corrosion products and ionic current flows that contribute to unwanted circuit elements.
- A measurement of the isolation resistance between circuit features therefore provides a direct circuit performance metric.
- SIR and CAF are examples of techniques that measure resistance, and hence provide Objective Evidence .
SIR, for process validation testing, was first established more than 30 years ago. It was a spin-off from the British CFC Elimination Project led by Dr Colin Lea OBE, at the British National Physical Laboratory. With the then advent of no-clean fluxes, it was the only test method to determine electro-chemical reliability and hence acceptable cleanliness as used at that time.
It was recognised as unsuitable for process control and that process ionic contamination testing (PICT) should be maintained for fast and effective control within 15 minutes.
New test methods have been introduced by IEC in the past 2 years:
- IEC 61189-5-502 – Surface Insulation Resistance (SIR) testing of assemblies - 2021
- IEC 61189-5-504 – Process Ionic Contamination Testing (PICT) - 2020
Gen3’s presentation will also look at the other test methods and compare their pro’s and con’s, including Ion Chromatography, FTIR, SEM + EDAX and new Digital Microscopy.
About GEN3
GEN3. Testing and measuring the electronics industry for over 40 years. For three generations, Gen3 have designed, engineered, manufactured, and distributed their test and measurement equipment into the electronics industry to shield their clients from failure in the field.
Their reputation for excellence has grown to a global scale. The team is made up of industry experts who work to set the standards around circuit testing, measurement, and compliance. They collaborate with key industry associations, offering our unique experience and expertise to educate all on what it takes to succeed. For product protection the preferred way is GEN3, where precision comes as standard, acting as a mentor and your front-line defender.
In the high-reliability arena, there is too much at stake to allow room for error. Testing must be finite and flawless. GEN3 understand the need for precision. Get closer to perfection by minimising your risk.
GEN3. Precision as Standard.
For more information, please visit our various platforms;
Website: https://www.gen3systems.com/
LinkedIn: https://www.linkedin.com/company/586317/
Twitter: @Gen3Systems
YouTube: https://www.youtube.com/user/Gen3Systems?ob=0
